Archive
Hello, as I am new to this system, I am unable to run all the features of hyper v. Can you please help me to learn hyper v backup and restore?
Read moreI own a Mac and I just bought my new hp support office jet pro 8600. Can you tell me if Mac supports it or not?
Read moreHello, I recently bought a hp scanner and I want to scan a pdf document. I want to scan a picture and later save it as PDF. As I am new to this scanner, please tell me to deal with the hp scan to pdf software?
Read moreHi, I recently got shifted to my new house. My printer worked fine before it got messed up with some issue. My hp wireless printer won’t connect now as I try. Do I need to re-install it? What is the issue?
Read moreHello, My system has a normal booting right now, I need to do the hp system recovery from Windows 7 in the easiest way. Can you help me out, please?
Read moreI bought a hp laptop a few days ago. I am also not able to find the hp support assistant contact number to be able to find a solution. Can you please, find me the contact number?
Read moreI want to reset my Acer computer and need to fully format the computer. Also need to make sure no data is recoverable because I am giving my system to other people. how to reset a Acer computer?
Read moreI want to replace many words in Excel and update them to a new version of words. I want to know how to replace words in Excel. Is there any quick way to change and replace the words in Excel?
Read moreI want to know how to replace ink cartridge HP printer and also need a way to make sure that it has been connected in the right way and also make sure that it is printing properly.
Read moreI want to replace the ink cartridge of my brother printer and also make a test print of the page check whether the new cartridge is working properly. How to replace ink cartridge?
Read more
