Archive
When an information passes from source to sink, but is lost in between then the phenomenon is called packet loss. How to fix packet loss?
Read more
When you open your outlook account, you might get error messages while sending or receiving SMTP emails. The error occurring at this time is 0x800ccc0f. How to fix outlook error 0x800ccc0f?
Read more
Memory leak happens when computer programs or the operating system cannot stop the unnecessary memory to release. This will drain all the available memory over time. It can result in blue screening of the computer or any other issues. How to fix memory leaks?
Read more
External hard drives as well as USB flash drives are easy to use. Sometimes, when you connect it to a PC it is not recognized. Problem can be due to the dear USB port or partition issues on the drive, or the driver problems. It may also be a case where the drive is dead. How to fix external hard drive not detected?
Read more
Many errors and warnings appear when we use a desktop. Some are application related and some are system related. The base is system. Some of the app errors are based on the system. Once we solve those errors app ones get solved automatically. how to fix event log errors?
Read more
JVM is an interpreter that converts java byte code to machine code. There are many issues faced. One such error message is –“java virtual machine could not find the main class-program will exit”. How to fix java virtual machine error?
Read more
It is irritating when your phone has only one main button and it gets damaged. Iphone 4 and 4s would get this irritation.How to fix home button on ipod?
Read more
When you try to switch on your desktop, but it takes a long time to boot, you may be prompted with an error message of error code 0x80004005. To start your computer properly, you have to remove this error. how to fix error code 0x80004005?
Read more
Imagine you are sitting in a restaurant and working on your laptop. But you have to pee urgently and went leaving the laptop only for two minutes. When you come back, it vanishes. This is a heart break moment for a laptop lover. how to find a stolen laptop without tracking software?
Read more
Your laptop contains all your important assignments and data files. if the laptop crashes down or doesn’t boot into your operating system, it is a heart break. To solve these issues we need to fix our gateway laptop. How to fix a gateway laptop?
Read more
