Archive
I want to convert the query I created in access using the wizard that query need to be typed as a program in SQL query. Is that possible to convert access query to SQL?
Read more
I want to convert bitmap images sent by the client to clean vectors for getting them printed on a very large scale to fit a banner board. The client provides us files to convert bitmap images to clean vector art.
Read more
I am an architect. I make many drawings of the buildings and interiors and used to send to theclient a screenshot of the design. Is there any way that I can convert AutoCAD drawing to pdf?
Read more
I want to convert audio to text free onlinefor me to be able to speak and the text to the documents written simultaneously. It would be faster to write documents like that.
Read more
To convert Adobe type files to PowerPoint type file having each page to each slide. Is it possible to do so automatically by having some app to convert Adobe to PowerPoint free?
Read more
I have been using Adobe acrobat to convert from PDF to Excel, but now the trial pack is over. And I don’t feel to buy it since I don’t have much usage of it. Is there any way to convert Adobe pdf to Excel free?
Read more
I have tried many online converters to convert PDF to word document but most of them were premium, and some were adding a bookmark. So I want to download the best app that can be used to convert Adobe acrobat to word.
Read more
I have been working with Microsoft access and have made an immense database now need to store it online to give access to other people as well. Is there any way to convert access to web application?
Read more
I want to add a graphic that I have created in aword to jpeg to add it into PowerPoint for my presentations. Can I convert a word doc to a jpeg so that it will be easy to store it in any other place also?
Read more
I want to convert a PDF file to Excel and make sure all of them have been converted to table format so that the data are not mingled. Which is the best tool?
Read more
