Archive
I have a jpeg file of a pattern which I need to convert it into a vector file so that it becomes more scalable and easier to resize to any scale without border blurs. How can I convert a jpeg to a vector file?
Read moreI need to convert a CD to audio CD so that it may be impossible to copy the music contained on the CD and also add more music to the CD. So how can I convert a cd to mp3?
Read moreI want to control the access of internet at home as I am having a limited plan and need to keep track of the usage and block access when it is crossing the limits. Is there a way of controlling internet access at home?
Read moreI need to know about Windows control panel. I came across this option control panel all control panel items. Can yourselfdelightenlighten me what is the usage of it?
Read moreI am want to check if the content blocked by your organisation. Is there any way by which I can make sure that the content is blocked or not?
Read moreAirwatch Secure Email Gateway seems to have a different method to control access to corporate email. For each of you who is deploying hosted or onsite systems and also the different ways to add security to your environments. Is this the same issue you are facing? Cause I am, and I need help.
Read moreHello, as I am a new user to Avaya Programming. I just bought a phone. Please tell me how I can reset and clear Avaya 9608 IP Phone settings?
Read moreI was going through SIP when I got stuck with PRI. Please tell me the exact difference between SPI and PRI to get my concept clear about it, so that I can work on it.
Read moreI just want to generate a new SID in my Windows 7. I read a lot of topic (Symantec, etc.) about Sysprep but it is difficult when you only want to change the name of SID in Windows 7.
If Sysprep loses profiles, installed software, it becomes useless to use an image file.
The unattend.xml solution seems difficult too. Can you please help?
Hello, as I was working with my sharp network scanner tool. I received an error implying ‘CE-02, Selected Servers not found. Please help me out with the possible solution?
Read more
