Archive
I have recently switched to a fresh ROM that was enlisted in ROM manager called the Codec ROM, but for some reason, now it shows that the “custom kernel hasn’t been flashed”, though my install had finished correctly. When I chose to "reboot" as suggested by the CWM, it went dead and did not turn on even after plugging to my PC or plug or even holding the power and volume keys together.
Please tell me how to fix my phone.
Read moreI want to take console of the Cisco Router at my workplace under my personal computer, sitting at home. I am a complete novice to Network Routing Protocols and the Internet too isn’t proving to be of much help. Can you provide me with the guidelines if the same can be made possible somehow?
Read moreMy internet connection seems to have some protection Issue because for every device in which I use internet on, I have to log in afresh to the network from my browser after WiFi is connected without which I am denied access to my network, and the connection shows “limited access” error on the status bar. I am using Windows 8 if that will help.
Read moreI have found an error in a particular data provided on Wikipedia and I want to edit it using the edit option provided. However, I cannot gain access whenever I moved forward with the process. Kindly tell me what are the correct steps to be followed to update data on Wikipedia. Thanks.
Read moreI want to know what is the meaning of this error message?
“This webpage is not available. ERR_CONNECTION_RESET”
Whenever I am trying to download anything from the web, I am facing this from any machine I use in my Local Area Network, irrespective of the established connection. If there is a way I can overcome this, please let me know.
Read more
I am getting certificate error for only one particular site which is preventing me from accessing the webpage. I am using Internet Explorer for Windows 7, and I can open all remaining sites without any error. Can u give me a probable reason and a solution to this issue?
My app is working fine on web but it is facing real-time errors when I’m trying to run it on mobile. I have used bootstrap and php to develop the front end. In case there are casual remedies I’m missing on, please suggest. My codes are working fine and there are no logical bugs.
Read more
I am using an Acer Aspire desktop PC, that runs on Windows 7 OS. The sound stopped working abruptly after I browsed a music site. If I assume that the sound card present in the motherboard of the CPU of my PC has failed, then is there any potential solution other than replacing the entire motherboard?
I want a good quality image, even after converting to it from a pdf file, since I need to edit it in Photoshop. So, how can I convert pdf files to tiff format because tiff images are high-quality images?
Read moreRecently, I got an email having an image attached in the format of .bmp. I researched a bit and found out that these are device independent bitmaps. How can I open it?
Read more
