Archive
Help! I have forgotten my Windows password. How do I proceed with linux windows password reset? I do not have a Windows password reset disk. Can someone please help me reset the password without the disk?
Read more
I am using the Linux Mint 17 Cinnamon desktop. I have run into a problem while trying to set up the linux mint desktop sharing using Vino VNC server or vino-server. But the vino-preferences tool for configuring vino-server no longer seems to exist. The desktop sharing menu is missing, too. How can I enable desktop sharing on my device?
Read more
I need to link gpo to ou. I am working with Windows Server 2008, and I need to know how to link a Group Policy object or GPO to an organizational unit or OU. Please provide the assistance I need.
Read more
I have pulled a Windows 2008 server into Windows 2003 server domain. When I attempted to promote the server to a Domain Controller, I got this error message. Error: The processing of Group Policy failed. Windows could not authenticate to the Active Directory service on a domain controller. (ldap bind function call failed). Look in the details tab for error code and description. The Error Code I got was 82 / Local Error. The Event ID is 1006. Please help with this problem.
Read more
I have encountered a problem while trying to use kiosk mode windows 7. I have a PC with NComputing access device L-Series and software vSpace 6.6.2.3. I want to enable Kiosk Mode so that I can start Windows applications straightaway. But I am having problems with this. How do I enable Kiosk Mode on my computer?
Read more
I am using Kaspersky security center 10,and I have run into a problem while doing so. I am trying to install updates. Due to time constraints, I need to do several at once. But because of the Windows time limit, I cannot take longer than 10 minutes. Because installing multiple updates takes longer than 10 minutes the system constantly interrupts while I am working. Please help with this problem.
Read more
I have encountered a problem while working with Oracle. Every time I try to open an Oracle form, I get the following error message.
To access this application, you must install the j2se plugin version 1.6.0_07. To install this plugin, click here to download the oaj2se.exe executable. Once the download is complete, double-click the oaj2se.exe file to install the plugin. You will be prompted to restart your browser when the installation is complete.
I installed j2se plugin version 1.6.0_07 as directed by the message. But I still could not open the Oracle form. Please help me find a...
Read more
Can anyone provide me with a link to download IE 10 for Windows 7 operation system. I have tried to download but instead of the setup I am getting only online installer. Can anyone get me IE 10 offline installer?
Read more
My IBM Server is not working and I need to check if the product is still under warranty or not. Is there any way to IBM server warranty lookup?
Read more
My IBM Server is not working and I need to check if the product is still under warranty or not. Is there any way to IBM serial number lookup?
Read more
