Archive
Earlier I was using Windows 7 in which Windows Search Service was there. Now I am using Windows Server 2012 in which Windows Search Service is disabled.How can I enable Windows search service server 2012 manually?
Read moreHow can I send Email via command line without any software? How can Windows send mail from command line? What are the steps to send Email?
Read moreI miss the old Start Menu on Windows Server 2012. How can I enable Windows server 2012 classic start menu on my system? What are the steps that I need to follow?
Read moreI am using Windows 2012 in which the usual Remote Desktop Window is not visible.How can I enable Windows server 2012 remote desktop? Can you advise?
Read moreI want to know about Windows Derver standard.What is the difference between Windows Server standard vs. data center? Are they technically identical? How many versions of Windows Server 2012 available?
Read moreWhen I run Windows Update I get an error Windows Update Client failed to detect with error 0x800b0001. I have rebooted my system plenty of times, but nothing worked. How can I fix this issue?
Read moreHow can I invoke Windows Update via command line? I want to know what is happening in the background. What do I need to type in the command prompt Windows update command line?
Read moreI have tried everything but I am not able to resolve this Windows update error 80070057. Please tell me the steps by which I can resolve this issue.
Read moreI am using Office Pro 2007. I want to download Powerpoint hotfix but when I try to update I receive an error message 'Windows update error 80070663'. Can you advise?
Read moreWhen I try to run Windows update by clicking on "Check for Updates" inside the Windows Update I get Windows update error 800b0001.How can I fix this error?
Read more
