Archive
I want to create a shared mailbox so that multiple users can access the same email account.How can I create a shared mailbox exchange 2010?
Read moreWhenever I start any audio service on my PC it always hangs on starting.Can you tell me any solution for windows Audio service hung on starting?
Read moreHow can I prevent the service host local system from using all system resources? It slows the system, reducing its efficiency.CPU utilization is more that it should be.
Read moreWhat is the best way to get alerted? I have heard about server room temperature monitoring device.What do they do? Do they alert via email or text notification?
Read moreWhat is server room temperature monitoring? Why is it necessary? Is it a reliable way for monitoring server room temperature? Water leaks are monitored or not?
Read moreI have a server room and it is a 10X10 closet. The room gets heated up. I have heard about sensors that monitor server room temperature. How does server room temperature sensor works? What is the optimal range of server room temperature?
Read moreMy server room gets heated up beyond the optimal temperture range. I need a device that will alert me when temperature of the server room increases. Can you suggest any server room temperature monitor email device?
Read moreHello Experts,
Recently I came up with an error notification regarding the time in my system that it was not in sync with the domain time. It is for the first time I am confronting with such a notification. Is it necessary that I should alter and sync time with domain? How can I sync it? Or should I continue with the present time?
I was trying to log in my computer but when the booting is completed I get stuck on applying computer settings. I am afraid if this could affect my system speed or hamper my memory. My system contains some highly official folders, how can get rid of this error and carry on with my work?
Hi, I want to install the terminal server windows 7. Earlier I was using the citrix server in my windows laptop. Can someone help me with information about how to install it in my windows computer?
Read more
