Archive
I am a user of Windows 8.1, and I often get these messages of invalid IP configuration. Especially when I restart my computer. When this problem occurs, all other devices would be working fine except this computer. Is there any way to prevent it happening.
Read more
Hello experts,
My computer is on some blacklist. When I try to access the internet the following message “does IP address comply with reverse hostname naming convention” is displayed. Did the firewall or DNS Setup has some problem. Or is it something with the ISP.
Read more
I am using Bluehost to host my website. I want to change the DNS redirect to URL as I specify. Also, make sure that the changes are effected immediately.
Read more
I am planning to buy a new DNS made the easy and I need some details about the basic services it should offer. I want a DNS made easy review
Read more
In Windows Operation system I want to configure DNS server Active Directory integration for DNS event id 4015. Which is throwing DNS_EVENT_DS_INTERFACE_ERROR as given by the id 4015
Read more
I want to disable the firewall on my Server Network. Also, prevent the users from changing the firewall settings. I particularly want it to be done with Group Policy object. Hence, I want to disable Windows firewall GPO
Read more
I have installed Java on my Windows 7 remote PC is any way by so that I can stop the notifications of Java updates or disable Java update registry. They always appear and have become a bit annoying.
Read more
I am using Windows 7 which is configured to use ipv6 automatically. Is there any way by which I can disable ipv6 Windows 7?
Read more
I am using Windows 97. I need to disable IPv6 group policy is there any way to do the same. Please provide with steps will be more useful
Read more
I have bought the Dell PowerEdge 7250, and I want to install the Dell asset tag utility. Can you post me the steps by which I can do the same?
Read more
