Archive
What are the various free patch management tools for Windows? How do the patch management tools determine what patches need to be installed by the patch manager?
Read moreWhat is the use of patching? What is free patch management software and how does it fix the bugs in a software product or an application?
Read moreHello, Okay in VLC player i know that you can press record button and record videos. when I record AVI Files there's no audio. I recorded others and had audio but what should i do?
Read moreTechyV, Can you please give me a step-by-step on how to put 5 folders from my desktop into a main Folder, also on my desktop. You see, at the end of the day, when I want to clean up my desktop, I want these 5 folders to be put away into this main Folder. Please pretend you are explaining it to a 7 year old. Thank you.
Read moreWhat is the ASCII value for ‘enter’ key or ‘carriage return’? How to determine ASCII value for any character?
Read moreHow to install SQL server 2008 r2 developer edition? What are the requirements and the instructions or steps for the installation process?
Read moreWhen SQL 2008 standard edition is run, an unhandled exception occurs with the error code "0x84B10001" and the set up fails. What must be done to successfully install and to run the same?
What is Microsoft SQL server? How to specify the date format and how one date format can be converted to another format in SQL server?
Read moreWhat is TP link 8 port router? What are its features and applications?
Read moreWhile installing or when we want to use the SQL server if we receive an error message such as ‘sql server does not exist or access denied’, what must be done to solve this problem?
Read more
