Archive
I’m about to install Solaris as guest OS through VMware, so I wanted to know about the Solaris Interview Questions and Answers. I’m looking forward to clearing the L2 stage, if you could only mention the important ones that would be great.
Read moreI’ve recently figured out that I should start coding and I’ve gone through many tutorials and stuff, but I’m yet to figure-out many things. So I ran into something called SQL, so I was wondering if SQL is a programming language.
Read moreHey there, I’m a web developer and recently formatted my HDD and lost all the useful apps setup’s, well I recovered almost all of them except for one. Can you provide me with SQL Server 2008 developer edition download link?
Read moreI want to know how to create a restore point because my system is being used by many people and there is often risk of me losing my data, how do i create a system restore point?
Read moreMy screen flickers when I use my system and open up some applications, I don’t know what is causing it although it only started happening after updating to windows 10. Solution?
Read moreMy Laptop battery is stuck at 0% and not charging any more, I can only work on my system when I plug the charger in and immediately shuts down when I disconnect the charger, solution?
Read moreThere is no sound in my system when I connect my Speakers and Headphones, I try to play media the system starts playing but no sound is generated. Solution?
Read moreMy Laptop is getting too hot to even touch whenever I start to run any graphic intensive application or a game like the visual studio, how to solve this problem?
Read moreMy monitor screen turned black after I changed the resolution to a higher ratio and now it won’t revert back to original, how to undo the change?
Read moreMy computer does not detect printer even though it is connected to the system and is receiving power from the outlet, how to resolve this problem?
Read more
