Archive
Hello everyone,
Today I got an error message from webpage “This operation requires that Microsoft Project Professional 2016 Preview is installed”. Why this error occurred? How can I fix this issue ASAP? Your assistance would be appreciated.
Message from webpage
This operation required that Microsoft Project Professional 2016 Preview is installed.
Read moreHello everyone,
I have installed Microsoft Office 64-bit in my Windows 8 Operating System. I have attached an error image so I expect a better solution to demolish this kind of issue. It would be really appreciated.
Setup Error
We can’t install the 64-bit version of Office because we found the following 32-bit programs on your PC:
Office 15 Click-to-Run Extensibility Component
Please uninstall all 32-bit Office programs, then retry installing 64-bit Office. If you want to install 32-bit Office instead, please run the 32-bit setup.
Read moreHi,
I hope you will be fine. I am facing a problem using Microsoft PowerPoint. I received this error message when I tried to open this application. How can I resolve this error message? Your help would be appreciated.
You can’t open the application “Microsoft PowerPoint” because it is not responding.
Read moreHello,
An error occurred when I tried to open photos but the system denies the access. I uploaded an image so you may understand this properly. Your assistance would be grateful to you. Thanks for your cooperation.
Error Applying Attributes
An error occurred applying attributes to the file:
…/ADA Update Survey Training Prese…
An assertion failure has occurred.
Read moreHi experts,
An error showed up when I tried to edit my presentation using Microsoft PowerPoint. I have installed this application on Windows 7 Operating System but I couldn’t view or edit my presentations. I have attached an error image. Please help me resolving this issue.
Microsoft PowerPoint isn’t your default program for viewing and editing presentations. Do you want to select files types that PowerPoint should open?
Read moreHello,
I have installed Microsoft PowerPoint in my Windows 7 Operating System. I received an error message preparing presentation “PowerPoint found a problem with content in Flash test.pptx. PowerPoint can attempt to repair the presentation.
If you trust the source of this presentation, click Repair. Help me resolve this error.
If you trust the source of this presentation, click...
Read moreHi,
I have installed word application in my Mac operating system but an error occurred “The server application, source file, or item cannot be found”. I have reinstalled the application but the problem persists. Need your suggestions.
The server application, source file, or item cannot be found.
Make sure the application is properly installed, and that it has not been deleted, moved, or renamed.
Read moreHi,
I am using Windows 7 Operating System and have linked my pc with server but an error occurred when I tried to open folders using Outlook program. I need help from experts. I would be grateful to you.
Microsoft Outlook
Cannot expand the folder. The set of folders cannot be opened. Network problem are preventing connection to Microsoft Exchange.
Read moreHi everyone,
I am using Mac Operating system and received a mail error message trying to access Microsoft outlook. The error is “Mail could not be received at this time”. I have also attached an error image so that you come up with better solution. Your assistance would be appreciated.
Mail could not be received at this time.
The server for account ******* returned the error “authentication failed” Your username/password or security settings may be incorrect. Would you like to try re-entering your password?
Read moreHi,
I have installed Mac Operating System and latest Microsoft Word application but an unexpected critical error occurred when tried to start this application. How can I fix this problem? I expect a better and suitable solution from your side. Thanks for your cooperation.
Unexpected critical error: can’t start program
Read more
