Archive
I have received the error message creating partition using software but remained unsuccessful. I think experts have solution for this problem. Would you like to share your ideas to fix this issue? Thanks for your cooperation.
Error
Failed to execute the command
ConvertNtfs2at DiskIndex:1 Partition:1
Error Code: 40
NTFS file system error. Please use “Check File System” function to fix it first.
Read more
Hello everyone,
I have been using Mac Operating System but got the error message using my app introcs.app that it has damaged and can’t be open. Is there any way to recover this app? If you could help then will be appreciated. Thanks!
Introcs.app is damaged and can’t be opened. You should move it to the Trash.
Read more
I am running Windows 8.1 32bit Operating system and received the error message when I tried to install my application. I have installed MSE and it stopped during initialization. I hope you can fix this issue. Need help ASAP. Thanks!
Microsoft Security Client
An error has occurred in the program during initialization. If this problem continues, please contact your system administrator.
Error code: 0x80073afc
Read more
I recently installed Microsoft Security Essential for my Window and found some virus during scanning process but when I click on actions apply an error message appeared “The actions you selected couldn’t be applied. I am unable to remove virus permanently due to this error. Help me resolving the problem. Thanks!
Windows Defender
Read more
I am running Windows 7 Operating System with Microsoft Security Essential but when I try to open my application an error message comes up “This app has been blocked for your protection”. I was running this app before without having any issue. How to resolve this problem?
User Account Control
This app has been blocked for your protection.
An administrator has blocked you from running this app. For more information, contact the administrator.
Read more
I am using Mac Operating System and got some extension error message saying “System extenion cannot be used”. I have tried several times by reinstalling it to fix the issue but can’t get any solution. Need help. Thanks!
System extension cannot be used
The system extension “/System/Library/Extension/AppleUSBEthernetHost.kext” was installed improperly and cannot be used. Please try reinstalling it, or contact product’s vendors for an update.
Read more
Currently, I am running 64 bit Operating Syetem Windows 7 and trying to install the Atom setup but every time I click on setup it throws me an error message “Installation has failed”. How I got this error and how to fix this issue easily? Your help would be grateful.
AtomSetup.exe
There was an error while installing the application. Check the setup log for more information and contact the author.
Read more
Hi experts,
I have been using Oracle software since 2010 but after updating I got this error message saying “You have not provided an email address”. Experts always know the solution of every problem so I hope best for the solution. Thanks!
My oracle Support Username/Email Address Not Specified
You have not provided an email address.
Do you wish to remain uninformed of critical security issues in your configuration?
Read more
Hello everyone,
I am worried while getting this windows script host error. I don’t know how to fix this issue. I have showed you the error image as I received. I expect a proper solution from you. Have a nice day. Thanks!
Windows Script Host
Cannot find script file “C:kernelr00t3r”.
Read more
I am trying to get installer online but it says “Installer” can’t be opened because it was not downloaded from the Mac App Store. I hope you one of your expert can fix this issue. Looking forward the applicable solution. Thanks!
Your security preferences allow installation of only apps from the Mac App Store.
Read more
