Archive
Hi everyone,
I am using Windows 8.1 Operating System and installed Logos Bible Software but suddenly it stopped working. How can I fix this error? It would be really appreciated if you guide me providing each step of solution. Thanks!
Logos Bible Software 5
Logos Bible Software 5 has stopped working
Read more
This morning I got this annoying error message using softlock license manager. Is there any way to resolve this error? I need detailed instructions to fix this problem as soon as possible. I look forward to hearing from you soon. Thanks!
F/X CAD
The security system (softlock license manager) is not functioning or is improperly installed.
Read more
An error message has come up using 3Dmark06 “The program can’t start because OpenAL32.dll is missing from your computer”. I have tried to resolve this error by reinstalling the program but could not get any positive response.
3Dmark06.exe – System Error
The program can’t start because OpenAL32.dll is missing from your computer. Try reinstalling the program to fix this problem.
Read more
I was using license manager to checkout my products working legally and properly but this morning I have come up with this error “License checkout failed”. Can you identify the solution of this problem? I would be really thankful to you.
License Manger Error .9
The hostid of your computer (“00269eac1b9a00ae646bb082”) does not match the hostid of the license
File (b79af).
Read more
I was using Skype for business purposes since 3 years but recently an error occured “Skype for Business has stopped working”. Need an expert to resolve this error. I expect high hopes from you to get a suitable solution. Thanks everyone.
Skype for Business
A problem caused the program to stop working correctly. Please close the program.
>Close the program
>Debug the program
Read more
I have Windows 7 Operating System having BlueStacks App Player but today it shows an error message “Your Graphics Drivers seem to be out-of-date. BlueStacks requires updated drivers to run. Update now?” What should I do? I am looking for some solution to fix this error. I hope you can know the solution. Help me. Thanks!
Read more
Hello experts,
I have been using Windows 7 32bit Operating System and received and error message “A serious error has been detected and Adobe EPIC_APP cannot continue”. I have tried to resolve the problem by reinstalling the software but no luck. Please fix this problem as soon as possible. Thanks!
Warning
A serious error has been detected and Adobe EPIC_APP cannot continue. Please reinstall the application and try again
Read more
I have been given this annoying error when I tried to launch Sims3. I am sure you can guide me perfectly to avoid this error. Your help would be appreciated. Thanks!
Sims3Launcer
Sims3Launcher has stopped working
Read more
Recently,
I just received Microsoft Office Outlook error showing “Cannot creat file: msg0000.wav. Right click the folder you want to create the file in, and then click properties on the shortcut menue to check your permission for the folder”. Have you any idea how to fix this error? Explain in detail please. Thanks!
Cannot creat file: msg0000.wav. Right click the folder you want to create the file in, and then click properties on the shortcut menue to check your permission for the folder.
Read more
Hi everyone,
I have been trying to prepare my upcoming projects using microsoft visual studio express 2012 but having some issue loading some projects while I opened only one project at a time. Can you fix this problem? I will surely greatful to you. Thanks.
Microsoft Visual Studio Express 2012 for Windows Desktop
One or more projects in the solution were not loaded correctly.
Please see the Output Windows for details.
Read more
