Archive
I have installed Windows XP and received this kind of annoyin gift “You may be a victim of software counterfeiting”. Is there any way to remove this error? I look forward your suggesions. I would be great to explain me in detail.
This copy of Windows is not genuin. Click this baloon to resolve now.
Read more
I have Sage Software to account for my daily expenses and transactions but today I received this exception error. I really can’t understand this kind of error so I need your help to fix this problem. I am sure you can fix this error. I will be thankful to you.
Sage 200 System Administration
Exception has been thrown by the target of an invocation.
Read more
Hi experts,
I am trying to restore my iPhone using iTunes but showed up an error message “The iPhone “iPhone” could not be restored. An unknown error occurred (53). Hope you can give me some ideas and suggestions to resolve this error. Thanks!
iTunes
Read more
Hi experts,
I am a oracle SQL developer and during working on data base I have received this disturbing error saying “The program can’t start because MSVCP100.dll is missing from your computer. Try reinstalling the program to fix this problem”. I did try to reinstall the program but couldn’t get any success. Can you get any solution? It would be great. Thanks!
Ppssppwindows64.exe – System Error
Read more
I am trying to download Adobe Digital Reader but get this error message “Unable to download”. I have tried every way to resolve this kind of error but could not understand how to fix it. I hope you can help to remove this problem. Thanks!
Unable to download
Error getting License, License Server Communication Problem
E_ACT_NOT_READY
Read more
Hi everyone,
I have bought my new iPad and not have enough knowledge about using this item. During saving my data I have received this storage error. I tried to manage the storage in settings but could not properly reach there. Can you please tell me step wise step to fix this error? It will be appreciated. Thanks!
Not Enough Storage
This iPad cannot be backed up because there is not enough iCloud storage available.
You can manage your storage in Settings.
Read more
Hello experts,
I am using the latest version of Acrobat Reader but it shows an error when I try to open the file saying it is not supported file type. I can’t understand this error so badly need your help to fix this situation. I hope you will guide me in better way to resolve the problem. It would be appreciated your cooperation.
Acrobat Reader
Adobe Acrobat Reader DC could not open ‘URLLink.acsm’ because it is either not a supported file type or because the file has been damaged (for example, it was sent as...
Read more
I am using MP Navigator EX using Windows XP 32 bit Operating System to scan my important documents but it kept saying “The scanner driver supported by this software is not installed. Install it and then retry”. I have tried to remove this error by installing the supported driver needed for this software but got nothing. Your assistance would be helpful. Thanks!
MP Navigator EX
The scanner driver supported by this software is not installed. Install it and then retry.
Read more
Hi experts,
I am trying to update my Software to iOS 9 but it shows failed error saying “An error occurred downloading iOS 9. How can I fix this software update error while I have tried now need assistance urgently? Looking forward your help. Thanks!
Software Update Failed
Read more
Hello everyone,
I am trying to run Stonesoft Ipsec VPN Client GUI but an annoying error comes up saying “Stonesoft Ipsec VPN Client GUI is already running on this machine Only one instance can be run at a time”. I closed another one but again the same error showed up. What should I do to remove this error? Help me. Thanks!
Failed to start Stonesoft IPsec VPN Client GUI
Stonesoft Ipsec VPN Client GUI is already running on this machine Only one instance can be run at a time.
Read more
