Archive
What are the methods to successfully double the number of registers on an ARM Processor (32 Bits) without any significant increase in the instruction size?
Read moreIn a DBMS, usually normalization is done for a relational database. What is this Normalization procedure? What is its purpose? What are the different normalization types?
Read moreIn a DBMS, what does security mean? What does authorization mean? Why are they required? Is authorization a type of security mechanism? What are the other security mechanisms implemented?
Read moreIBM has recently released a new IBM mainframe named z13s. What is the purpose of it? What are its features and how does it improve security for Hybrid Cloud?
Read moreWhat is an entity-relationship diagram? What are the different components of an entity relationship diagram? What are the advantages of using an ER Diagram?
Read moreWhat does constraints in SQL mean? Which are the different types of Integrity Constraints? What happens if a constraint is violated?
Read moreWhat are the different types of keys used in relational DBMS? What is the purpose of primary key? What is the difference between a primary key and unique key
Read moreWhat is an interrupt in an instruction cycle? How to deal with an interrupt? Also, in what part of the instruction cycle does the processor check for interrupts?
Read moreWhat is the meaning of pipelining in computer architecture? What are the advantages of the pipelining structure?
Read moreIn a C Program, a component called Header File is compulsorily included in every program. What are these header files? What is their purpose? What will happen if we don’t include them?
Read more
