Archive
Rootkits contain code that allows the hacker to hide their presence and use the client browser efficiently. This can cause problems of electronic money theft or stealing of personal information. How to remove rootkits from your computer?
Read moreYour PC might display a problem of several mysterious svchost.exe processes. When 1 or 2 such processes appear, it is bearable but what if it exists in dozens. It is hard to remove these processes because they return back. How to remove svchost virus?
Read moreSSL certificates are also called as Digital certificates. They establish a secure connection between the server and browser. It protects the data like credit card information. If you already have one, you might have to renew it. how to renew ssl certificate in iis 7?
Read moreTrojan is a type of malware which enters into a file and then embeds into the system. It can mess up you PC by crashing down the device, corrupting the data or even delete files. Electronic money theft can also be carried through this virus. In order to protect you PC from all the above circumstances, it is a must to remove Trojan. Explain methods of getting rid of Trojan virus?
Read morewhile buying an iPhone, the names in it are default. To recognize whether it is yours or not, you need to make changes in it. One of the changes is to rename your iPhone. how to rename your iPhone?
Read moreEvery coin has two sides. Internet has helped but cybercrime is the con. Hackers use ‘ransom ware’ to lock your device, and demand ransom for the access. Prevention is better than cure. It is better to know how to avoid it. how to remove ransom virus?
Read moreYou might have purchased a Norton antivirus for a certain time. It might have reached the expiry date and you need to install some other antivirus. For this you have to remove Norton from your PC. How to remove Norton 360?
Read moreYou might have purchased a Mcafee antivirus for a certain time. It might have reached the expiry date and you need to install some other antivirus. For this you have to remove mcafee from your PC. how to remove mcafee from windows 7?
Read moreEvery coin has two sides. Internet has helped but cybercrime is the con. Hackers use malware to steal money, personal information or preventing the user from using their device. Prevention is better than cure. We need to take steps to prevent our computers from malware. how to remove malware from computer?
Read moreSometimes, due to a virus entering your PC or internal problems, PC might restart again and again. This may be irritating and wastage of time. In this case, solution is to restore your computer. How to factory reset a dell inspiron?
Read more
