Archive
Scratches affect the quality of the picture. Though deep scratches are difficult to remove, there are some home remedies for lcd tv screen scratch repair.
Read more
Switching operates at layer 2 of OSI model whereas the Routing operators at layer 3. The devices in the same layer 2 do not require routing to local ones. Differentiate between layer 2 and layer 3 switches?
Read more
The basic difference between color laser and mono laser printers is that mono laser can print only in black and white whereas the other one can print in color. Mono lasers are preferred by small businesses. Describe laser black and white printers?
Read more
When in a market you need to decide to choose form a standard printer or multi-function device. It is a tough job to decide to invest in a laser or inkjet. How to choose laser color printer for home use?
Read more
Though the laser printers do not necessarily require a different paper. We can use copy papers to take the printout. But for better performance, special papers are preferred. It can even happen that the laser printers het damaged when wrong media. Differentiate laser paper vs copy paper.Though the laser printers do not necessarily require a different paper. We can use copy papers to take the printout. But for better performance, special papers are preferred. It can even happen that the laser printers het damaged when wrong media. Differentiate laser paper vs copy paper.
Read more
Lotus notes are used to store the large data of a firm. A business uses it for communication between the members and organizes the messy data. How lotus notes to SharePoint migration done?
Read more
Windows 8 is among the latest operating system available. Though it has better features and high performance, people prefer Windows 7 for its user- friendly feature. How to get laptop windows 7 home premium?
Read more
It is necessary to ensure that the latest software is being used so that we get the best performance and features from the smartphone. You should regularly update the OS. How to update to get the latest android os for tablets?
Read more
AD stored the last logon time. It is stored in Last-logon AD user object attribute. This feature is only updated in the domain controller. So we can find it through the DC’s. How to find last logon time active directory?
Read more
Multiple versions of dot net framework can be installed in a single machine. The version should be known at the time of development of an application. How to determine the latest dot net framework version installed?
Read more
