Archive
Hey, I would like to buy a laptop for world of Warcraft at the lowest budget. I have no knowledge of specification required in the laptop for I need to play this game. Can anybody please tell me something about specs?
Read moreI have a Dell laptop and when I turn it on the screen remains black. So I tried to holding the power button to shut it off. Then I waited for 30-40 seconds and turned it on again and still laptop screen won’t turn on. What is the problem here?
Read moreI had a doubt in my mind to know if there is any kind of difference in LAN cable vs. Ethernet cable.
Read moreI am repeatedly getting an error message to install a waste toner box. When installed, I go to print and it started beeping. Do I own a Konica Minolta waste toner box, if anyone can help?
Read moreHello, if I have my computer setup with 2 monitors and My other device with many few monitors, is there a KVM switch for multiple monitors which can support this?
Read moreHello, Can I be able to run through a KVM switch HDMI dual monitor so I can use it with both of my desktops as well as the laptop?
Read moreI need to get my Dymo LabelWriter 400 to start on my PC when attached to my port. For that, first I need to know about all the label for Dymo label writer 400.
Read moreHello, once there was an issue with something on my computer and accidentally, I unplugged the firewire and that reacted to my LaCie drives from the IMac. From that day, they won't mount. I tried to reconnect them and also tried turning them on and off but nothing worked out. Can anyone fix my LaCie external hard drive not recognized in Mac?
Read moreHi, I own a LaCie external hard drive which control panel shows up but does not appear as any drive in Windows Explorer. Can anybody fix my LaCie external hard drive not recognized?
Read moreHello, I was using one of my LaCie Rugged Mini storage devices. Suddenly, it got removed even when it was at its same place and unmoved. Now, when I tried to connect it again. It shows nothing. I am searching for the LaCie tech support phone number, but I could find it nowhere. Can anyone get it for me?
Read more
