Archive
Snipping tool is present in Windows 7,8,10,Vista.the way we take screenshots of important things in our cell phone, the same way wen can take screenshots in our desktop usin the tool ‘snipping tool’. How to find the snipping tool to take the screenshot?
Read moreIf you have an iOS device and you enter a wrong password for 6 times, your device will be locked and disabled. That means all the data in it will be lost, until and unless a back-up is done. How to fix a disabled iPod?
Read moreIf the iPod is not reacting to your taps, or your music player is not working etc. then it is irritating. These issues show up when iPod has frozen. How to fix a iPod Nano when it freezes?
Read moreAny broken/infected part of a computer can be harmful for its performance. But some problems can be solved at personal level. Computer repair is necessary because we rely on the system for our personal as well as professional life. how to fix a broken computer on your own?
Read moreRUN DLL error is concerned with DLL files that store a huge amount of data. It is a part of large records of data and codes used by a programmer. This error comes to the picture when the program has no access to the code written to execute various tasks by various programs at a particular time. how to fix a rundll error to save our DLL files?
Read moreGPS would be in one of the top positions, if we would be asked to select the features in our phone. It informs us about the route, helps parents to keep the track of their children etc. how to find cell location?
Read moreWhen you have two macs, you need to transfer data from one mac to other from time to time or when your friend asks you for some data, you need to share files between the mac books. How to file share between macs?
Read morePlease detail about how to file cybercrime complaint explain detail about.
Read morewhen your mobile screen gets frozen, app crash, keypad touch problems arise, cannot hear from the phone, phone makes noise, cannot make or receive calls etc. then the solution is to factory reset your device how to factory reset note 4
Read moreToshiba laptops have the factory software image stored in a hidden place on the hard drive. You can restore your PC from this hidden place only. How to factory reset a Toshiba laptop?
Read more
