Archive
I want to install team viewer in my system, and I have windows 10. Would it be possible to install team viewer in windows 10 and how to install team viewer 10 in my system?
Read more
I want to install exchange 2010 in my system as Microsoft had stopped the technical help related to exchange 2007. How to install exchange 2010 on my system?
Read more
I am a graphic designer student, and I want to install Corel draw x6 on my system. I have downloaded the setup but not able to crack it completely. How to install Corel draw x6 on my computer?
Read more
I am a graphic designer student, and I want to install Corel draw x5 on my system. I have downloaded the setup but not able to crack it completely. How to install Corel draw x5 on my computer?
Read more
I am a graphic designer student, and I want to install Corel draw x3 on my system. I have downloaded the setup but not able to crack it completely. How to install Corel draw x3 on my computer?
Read more
I want to install adobe acrobat on my system to open the pdf files and other things. I want to get an Adobe Acrobat reader and install it, but I am facing an issue. How to install adobe acrobat on my system?
Read more
My SD card had stopped working on my android phone, and my files are getting corrupt. The documents have stopped working already, and now my pictures are getting damaged day by day. How to fix sd card errors on my device?
Read more
My system is not properly working due to some svchost error. I am really worried as my files are getting corrupt and are not opening properly. How to fix scvhost.exe error in my error?
Read more
I am facing an issue with my system due to some .dll files due to which my system is not working properly. Also, they are making the performance of my system lower. How to get rid of dll files so that they do not affect my, system.
Read more
I am a student, and I admire of acquiring an MCP certificate so that I can work with Microsoft over different solutions and technical issues. I don’t know how to get MCP certification and the requirements for it. Will you guide me through this?
Read more
