Archive
I need to convert my XPS file to PDF. Is there any XPS to PDF converter. Can I download any such application for free? Also, can we do this online?
Read moreI am currently using Windows 8 on my PC. Is there a way to run XP on a virtual machine in Windows 8? Please suggest.
Read moreI am currently using Windows XP. I have to upgrade to Windows 7. What are the steps to install Windows 7 on your PC? I have bought a licensed Windows 7 DVD.
Read moreI am currently using Windows XP and need to migrate to Windows 7. However, I have skipped the Windows Vista update. Is there any way to transfer files and settings to 7?
Read moreI am currently using Windows XP and need to easily transfer all my files and settings to Windows7. Is there any software or application that manages this task?
Read moreI need to fix registry changes in ‘xml dom document 6.0 msxml6.dll’ of Microsoft XML 6.0 SP2. How do I make the changes? Please suggest.
Read moreI need to fix registry changes in ‘xmldom document 3.0 msxml3.dll’ of Microsoft XML 3.0 SP1. How do I make the changes? Please suggest.
Read moreI am having trouble connecting to my Xfinity WiFi network. Can anybody suggest the procedure of how to connect? I am using Windows 8 on my PC.
Read morewhat is the process of downloading oxycube for nokia 5130 which allows us to view our phone on pc? what are advantages and what type of data can we access ?
Read moreMany laptop owners face the common issue of laptop battery draining after some 3 years of usage of the machine. so, how can a user keep a check to this problem just by using acer battery life extender? are there any softwares which can extend and enhance the battery performance (or) any hardware and software modifications?
Read more
