Archive
Hello, notify the virtualization software for windows 7 and the system requirements too for it as thanks for the solutions as well.
Read moreHello, notify the virtual server vs physical server and its comparison too and notify 5-6 points for the same as well and thanks for the solutions too.
Read moreHello, notify the file size for the virtual pc 2007 64 bit with the supports OS too for it and revert soon for it and thanks for the solutions too.
Read moreHello, notify about the virtual desktops for windows 7 and its key features as well and thanks for the solutions too and revert soon too.
Read moreWhat is IP phones? What is the working methodology behind IP phones? How can we configure/ setup the NEC IP phones?
Read moreWhat is meant by net backup? What is the job of a scratch pool? How the net backup scratch pool works? What exactly it’s done with the help of the net backup scratch pool?
Read moreWhat is meant by CDR? What is the use of Cisco CDR reporting software? How can we use its applications?
Read moreWhat is meant by CSVDE? How can the user use CSVDE import and export the CSV format files? What are the advantages and Disadvantages of using CSVDE?
Read moreWhat Ithaca? What are problems in the Ithaca printer? How can we solve the problems caused in the printer? How can we trouble shoot the issues?
Read moreWhat is meant by Error? What is error code 80244o2c which occurs in Windows 7? How can we come over that problem?
Read more
