Archive
After installing Adobe LiveCycle Designer when adding UI element interactive form in NWDS and click on ‘edit’ it hangs and also when going to SAPGui. Transition SFP and click on layout, again the session hangs. How can we fix this issue?
Read moreWhile opening Adobe fireworks CS6 it refuses to run, and there is a popup menu saying “an internal error occurred.” The popup menu will not respond, and the task manager is used for closing fireworks. How to resolve this problem?
When using Adobe Photoshop you have completed with your work, and it looks good, but when you upload your work it gets all messed up and blurry, but if you print, it turns out to be the same. Why is it so?
Read moreWhile coming from work tonight, my phone got stolen in the metro. I don’t know what to do, can someone help? It contained a lot of information.
Read moreMy son was using my phone to play games, and he by mistake made my phone to reset. Can I get my data back? Or is it lost forever?
Read moreI like listening to songs, but I think my speaker has gone down as it has stopped working recently. Can it be fixed, or do I need to buy a new speaker?
Read moreMy laptop’s touchpad has stopped working. It was working fine. I don’t think there is a problem with the hardware as my laptop didn’t fell anywhere or something like that. Can it be turned on or off by some button or using the control panel?
Read moreWhen I open a program I want, then it pops up a message that says “less visual memory.” What can be the reason for this? I have visual drivers and boosters installed, but they do not work. What should I do?
Read moreWhat is the best to way clean your monitors? Can I just use water or wiping them dry is okay?
Read moreMy cabinet is very dirty, all the fans have dirt collected all over them, the motherboard and wires all covered in large amounts of dust. How should I clean them?
Read more
