Archive
When I try to call someone using my One Plus 7 pro on Google Duo, the image of the person on video call appears on the screen, after some time it movies slowly and then it stops. I tried to force stop the application, delete the application, restart the phone and then reinstall it but nothing is working. How can I fix this issue?
Read moreI just bought this Lenovo IdeaPad 330 and I can’t seem to enable touchpad scrolling. The touchpad itself is working, it’s not scrolling. I searched online, it says that it is the problem of windows 10, I read that by enabling settings under Mouse Properties in the ELAN tab will fix the problem, but when I go there, there’s no device listed. How can I fix this problem?
Read moreI purchased a new laptop a few days ago, it keeps restarting itself, it shows a message that “something’s wrong with your PC. Restarting it.” Is it because some virus is present in the PC or something else because it already contains antivirus. Is it some hardware or software issue? How can I fix this?
Read moreI often face this issue on my smartphone. When I try to open an app, it gives me this warning.”Warning: Less than 100MB space left. Please free some space to continue using this app successfully.” How do I fix this the issue?
Read moreI am a Windows 10 user. I have a problem with the WiFi. It keeps on frequently disconnecting on its own. This is creating problems while I am working on my laptop. Is there any solution how can I fix this?
Read moreI am a windows 10 user. I think there is a corrupt installation as there are some issues with the start menu or Cortana. Some icons on the taskbar have stopped responding. I do not know how to fix this. How can I solve the problem?
Read moreI am a Windows 10 user. Recently I noticed that my task manager was using more than 20% of CPU on its own. Is this a problem? If so. how can
Read moreI am using Nexus 5 phone for some months now. Recently it got the Android Marshmallow update, But after the marshmallow update my front camera icon has disappeared or I am unable to find it. Is there a solution for this?
Read moreI am an iPhone user, and I use my iPhone to create a hotspot to connect my laptop to the internet. But the issue is that the iPhone’s hotspot is slow. Is there a way in which I can fix this?
Read moreI have purchased a brand new LG G7. It is working fine, but the only issue I have is that it does not show the battery percentage on the status bar even if all the settings are enabled. It only shows up when the top panel is pulled down. How can I fix this?
Read more
