Archive
Have you ever noticed that your external storage device is showing just a few megabytes of space in your Windows OS? Here is how to reallocate drive space in Windows.
I’ve recently found that my disk space is full. I’ve deleted all unnecessary files but that made only a minor change. I also noticed a lot of duplicate files I found myself, compared and deleted but that is taking a lot of time and effort. I don’t want to lose important data. What can I do?
Read moreSince I have updated my phone to the latest Android Pie, I am not able to use the screenshot commands. This is making it difficult to share the screenshots on the third-party apps. Moreover, I am not able to delete the screenshot from the pull-down menu since there is no option to. Should I wait for more updates?
Read moreIn the latest Android Pie, the guaranteed feature was the smart screen rotation. However, in my android device, even after updating the launcher, I am not able to use the smart screen rotation. Could this be a software issue or does my phone not support the option? Should I wait for further updates?
Read moreIn android Pie, I am not able to use the navigation feature that I could use in Android Oreo. I have to click on the home button for the app drawer instead of swiping up. Is this some issue of the screen or has touch become weak? Can I install a third-party launcher for the navigation?
Read moreScreen pinning option is not available in the latest Android version. After the update, I am not able to pin the screen by the conventional method. Is this option removed in the new update? Can any third-party apps be used for the screen pinning? Is the feature removed? Will it be reverted in the future updates?
Read moreAfter the latest update, Android Pie, I am not able to find the option to split the screen. The issue here is, I am not able to use two apps at a time because of this. The problem has started with the latest Android update and was working fine in the previous android version.
Read moreDuring my PHP programming, an analysis error occurred. The error says Analysis error: syntax error, unexpected T_BOOLEAN_AND in ... online ... How can I fix this error?
Read moreDuring my PHP programming, an analysis error occurred. The error says A session has already started, with session_start () in ignored How can I fix this error?
Read moreDuring my PHP programming, an analysis error occurred. The error says Parse error: syntax error, unexpected T_STRING in ... How can I fix this error?
Read more
