Archive
Recent issue I faced in my laptop was that after I installed Android Studio software in desktop got slowdown because of its huge capacity to run on 4 GB RAM and also in Task manager CPU increased in 95% which was a major problem for the decreased performance of Computer speed.
Read moreThe recent issue I faced with my new One Plus 7 Pro was a sudden shut down of the device. This came after a seamless usage of 4 days. The device would not switch on by the conventional method, long-press the power button. It began with the freezing of Whatsapp on the device.
Read moreHow to run older programs/applications made for older versions of Windows such as 98/2000/Windows 7 etc, on a Windows 10 either using the in-built compatibility mode without any errors or issues?
Read moreI bought this HP computer year back. Everything was working fine as I have kept it for work purpose. There is not single downloaded stuff like movies or games. Soon after time whenever I started typing something on the search box or anything, it types automatically without any break and stops suddenly. The keyboard has started to type a letter multiple times even though the key is pressed only once.
Read moreRecently my phone was not detecting my SD card. I tried rebooting my phone and inserting the SD card again and again. None of it worked. I thought the SD card was corrupt so I bought a new one. And it was working perfectly. Can anyone give a solution how can I repair my SD card?
Read moreWhy Nokia 6.1 Plus is shutting down unexpectedly? How can you resolve this issue?
Read moreWe all may have used various applications on our mobile phones. The most common problem in many mobile phones is that while using an application, it stops responding or slows down. Why do an application stops responding or slows down while using it and how can be this problem fixed?
Read moreDoes increasing the RAM of a system actually help increase the performance of a system? Or should one consider upgrading the Memory of the system from hard drive to solid state drive? Which one will bump the performance and how?
Read moreI am playing Fallout 76 on PlayStation 4, most of the time. Though I have a computer to play the game, I often choose PS4 because it is a lot faster. You don’t have to wait for the operating system to boot before you can play. You just need to turn on the console and start playing. But I’m just wondering, how come sometimes I see rainbow-like colors in the game? Turning off then turning on the TV doesn’t solve the problem. It doesn’t happen always but I wish I knew how to fix it.
Read moreI have a Sony PlayStation 4 and a computer with 64-bit Windows 7 and I play Fallout 76 on both devices. But, most of the time, I play with my PlayStation 4. How do you fix if Fallout 76 freezes on PlayStation 4? I don’t usually experience it but it’s annoying when it happens. I usually just restart the console and load the game again. Is there a way to avoid it?
Read more
