Archive
Hi! I am unable to update my windows. Whenever I try to update it, I receive this ‘windowsupdate_8024402c’ error message. What can I do to update it?
After starting my computer, I’m receiving this ‘cscomp dll is missing from your computer’ error message. How can I fix this?
Read moreWhen I build my system, I continue to receive the lua5.1.dll message. but do I stop and what should I do?
I created a Win32 project with code in Visual Studio 2015. I compiled it successfully, but I can not start the exe file because I do not have ucrtbased.dll ... Anyway, can I solve it?
I have a previous program, Edmark Thinkin 'Things One (for Windows 95), that I would like to install with XP on my laptop, but it says the file is missing the file mfc30. Dll windows 7. How can I fix it?
I have an FDB (Firebird) file from a new buyer (he does not understand the version). In fact, I tried to use a graphical interface to access the information, but without success. All say that its gds32.dll is missing, but I did it. I derived this DLL in the GUI folder, I actually derived the DLL in the System32 folder and I derived it in syswow64. I am using Windows 7 64 bit and Firebird information is also 32 bit. I actually tried to put in the DLL, but I can not save it. I checked WinXP in a very...
Read moreEvery week I can not play MPEG video recordings anymore. It prompts ffmpeg.dll download failed. How can I fix this?
I recently upgraded from 2015 to Effects 2015. I am currently buying a missing AfterFXLib.dll message after attempting to open it. In fact, I reinstalled it twice. Do you have any suggestions?
In recent weeks, the default application was used for gap or video files, and I have an open file for which I bought an incorrect calculation language, Windows does not recognize the file and displays the path of access to the file. Then he suggests that I check my information and check again. This can be the case by clicking on the nail. After reviewing the default applications, I see that a TWINUI has been set as the default. After catching up, I still see TWINUI as a partner in the choice of nursing. Is it possible to remove...
Read moreWhen I launch Photoshop CC (20.0), the Photoshop.exe command dialog box appears saying D3DCOMPILER_47.dll is missing. Try to reinstall the program to correct this inconvenience.
How can I solve this problem?
