Archive
I am using my windows for a long duration. Now when I am trying to logging, it is showing an error message with code 0x80090019. The description says that there is some problem with checking the license of the windows. It is then logging out. What can I do now?
In my system, when I tried to shut down the system, it is showing a blue screen with error 0x00000d1. I think I have not done any installation that is updated wrongly. It just happened suddenly. It says that it is related to Iastora.sys. What can be the reason for this?
I have an Xbox account for one year, and I am a regular user. Now when I am playing songs, they are stopped for 10-15 minutes and giving an error Xbox one 0x800c0005. I am even unable to join the parties. Rest all the features are working well with no issues.
My system used to work well until yesterday. Last night I tried to install a game and started the process, but after finding that it contains malware, I stopped it. Now when I am trying to open the system, it is showing error 0xc00000ba file download something like this.
On my laptop even I am using it for one year I haven't installed anything other than basic stuff. Now when I am trying to check for the updates, it is showing error windowsupdate_80070005 windows 7. What can happen to the system all of a sudden? Why does this error occur?
I am using a system for the past ten years. There are so many files in the system and are running out of space. So I thought of converting WAV files into WMA files. I downloaded the Windows Media Encoder. Whenever I try to transform it is showing error code couldn't find sufficient file error 0xc00d1b83.
Read moreI got a new X box. I have an X box account and am using it for months. Now when I am trying to create my profile in this new one, it is showing error code 0x80a40019. I tried to reset the configuration and started it again, but there is no use. How to get this solved?
My system worked well a week ago. When I opened it today and tried to refresh it by using f5 it is showing crw32.exe download is having a problem. I have all the Crystal Reports 2008 installation files. There are no other new installations. What can be the reason for this problem?
I am using my HP printer for about two years. It has never shown any problem. Now it is showing there is some problem with the printer with error code 0xc19a0003 when I am trying to use it. I tried some regular solutions, but there is no work. How can I solve it?
Due to the heavy load, I reboot my system. It used to work fine before the reboot. After the reboot I received the message that the operating system not found please install. Both the memory and hard drive are working fine. When I tried with a startup repair, I got error code 80004001. How to solve it?
