Archive
I get the dbisam engine error 8961 and I can not do much with open tabs, etc. I guess it's a simple regedit fix, but I'd rather know in advance what key I'd like to erase instead of tearing up the recording. Please, let me avoid this error in the future if it was absolutely something that my colleagues did. Thanks for the help.
Read more
I can not add new folders to Fast Access.since an error occurs that says an api call exited abnormally. Please help us to fix this problem.
Read more
I have the key Windows 7, I typed and activated, and so far everything was fine as soon as it was reported that my copy was not authentic. I have tried repeatedly to enter the code and it continues to give the US federal state the error code mentioned above: error code 0xC004F063 windows 7. Please, facilitate validation!
Read more
In the past few days, after taking out my laptop from hibernation, I bought the following error message: Access violation at address 00401C55 in the 'TeaTimer.exe' module. Write to address 00000001. What exactly is happening here as it shows the teatimer exe access violation?
Read more
I have a Dell Studio 1458 with Windows 7, six months ago. It usually hangs and leads to a blue screen with the message Bad_Header_Pool. Does anyone have its solution? Please help!
Read more
After performing a Windows update, I receive the following error message while you work. "The purpose of the nextafter procedure entry could not be set in the MSVCR120_CLR0400.dll dynamic-link library.” What does this mean and how are we going to solve it, and currently I realize that Skype for Business search does not find anything either.
Read more
Zune 120 GB displays an error message “Contact support 5”. I followed the reset instructions, but still no luck. How will I solve this issue of Zune contact support 5?
Read more
I have a KMS server (Server 2008 R2) that accepts activation requests but has an error with event ID 0xC004F041 indicating that the server wants activation. The server is already activated and I tried to reactivate it with slmgr / ato. Please someone will advise?
Read more
My system blocks various games which I play on the web and gives error 0xc00000ba. Any solutions for how to fix 0xc00000ba?
Read more
I just received an error code 0x800413032 in my system. I have been through a lot of blog posts and their methods but nothing resolves the issue. Can you help me solve it?
Read more
