Archive
I am facing the connection error 0x2102 in my system. I have spent a lot on my system to improve this and remove this error. Anybody is aware of how can I solve it?
Read more
How to resolve the error message "Thunking Spooler Apis 32 to 64-bit process stops working" on my multifunction printer?
Read more
I had to uninstall Windows 10 and go back to Windows 7. When did AVG do that? I had to restart. This has been done and it has already been mentioned that I had to solve the problem. Tried to repair, but would not work. I tried to uninstall, so I can install, but I will not uninstall. What should I do to solve error 0xe0010002?
Read more
I wrote a simple generator DLL plugin [1] on my laptop (Visual Studio 2017, Windows 10) written in C ++ / CLI with only one category and one method, and tried to test it. distribute to some colleagues. The results were mixed: some machines were fined abroad but others were dropped. When debugging the generator on each of the failed computers, I noticed that this line: Assembly.LoadFrom (name); thrown an exception with HRESULT -2147024770.
Read more
I am trying to update Windows 7, but the following error code "WindowsUpdate_80070BC9" is displayed. Does anyone know what to do to try to find a solution?
Read more
I was suggested to do the medical specialty hollow on my disk. It contains the error code 0F00: 0244, which also indicates the seasonal. DISK_0-BLOCK 27540752 CAN NOT BROWSE, REPLACE DISC OR REMOVE WRITE PROTECTION. Is this terminal? Please facilitate with tips.
Read more
Can anyone help the US state with this inconvenience because I can not use the Windows update program because of the Windows update error 0x8008005 as declared in Windows Update Diagnostic and 0X80080005 in the Windows update program?
Read more
I own a HP G6 laptop with a removable cover. As soon as I install games, they are simply executed. My nephew can not run one in all his games because he wants this program, but every time I try to install it, he fails. It gives installation failed with error code 0x00000424. Please help me solve it.
Read more
When I try to perform a major installation of Microsoft Windows System Resource Manager (WSRM) by sacrificing the Microsoft Windows Installer package for WSRM, I fail. When I try to create the WSRM Executive installation package for network installation by using the msiexec / a Path command: \ wsrm.msi, you receive the following error message “1038 source file not found”. How can I fix this?
Read more
I shifted to Windows 7 from Windows XP. The good fax does not work anymore. I receive the rightfax error 1722. Can you guess what action is needed?
Read more
