Archive
When I try to connect anything to my computer using BlueTooth, I get the bttray exe application error and then the device fails to connect to my computer. I am facing this issue for several days now. How should I proceed with this?
Read more
I was suggested to ijl15 dll 64 bit download by Windows when I was trying to work with some JPEG files. I like to dabble with photo editing and I have seen this pop-up a few times too many. Is this file safe to download and is it necessary?
Read more
Whenever I use yahoo mail or reading emails on yahoo mail, I keep getting the npctrl dll pop-up and it asks me if I want to install this add-on. I do not know what this is. Am I infected or is it just some advertising?
Read more
I am trying to connect Oracle ODBC to my Microsoft Excel. I use a 32-bit Windows Operating System. When I try to do so, the system throws sqoras32 dll could not be found an error. Is it possible to remove this error?
Read more
I haven’t been able to install automatic Windows Updates on my Windows 10 PC. I keep getting error code 0x8024a105 before the updates finish. I have tried installing after disabling the firewall and antivirus, but this has not worked for me. Can I resolve this issue?
Read more
Whenever I try to install updates on my Windows machine, it always finishes with an error code 0x800070005. How should I go ahead with these updates? I understand how important installing updates is.
Read more
I use an HP computer. Mentioning this is important because I am having trouble with something that is only present on HP computers. Sometimes, when I open the HP Support Assistant, it gives hpsf.exe error and hpsf update. How to remove this?
Read more
I am having trouble installing the Windows Updates. I use Windows 10. I am trying to install the automatic updates on my system, I keep getting the windows error code 80246005. How do I move forward with the updates?
Read more
I randomly started getting this error code 0xc000022 from Windows. To help you out, let me inform you that my system is completely updated and I have not installed any new programs. I do not know much about computers. How do I remove this from my system?
Read more
I recently upgraded to Windows 7 from Windows XP. No, I was not living under a rock. I was trying to install a card reader for my computer that worked on my Windows XP machine. The reader is Gemsafe Card Reader. It is showing scardsvr exe is missing windows 7 error. How to solve this?
Read more
