Archive
HP LJ300 m375 reports "HP scanner error 6, close-up, re-ignition" as soon as I scan a document on my PC. I close (and even reverse) and turn it back on and it still allows me to scan, so the error is back and I can not scan again until I shut down and turn on again. I do not get this error after searching for a USB flash drive. How can I buy to avoid this error?
Read more
I use outlook for my various purposes and but today when I opened it it popped up an error message that says 0x80040900. Can anyone help me solve this outlook error code 0x80040900?
Read more
Today when I opened my browser and looked for a link and suddenly it shows up a blank page and now no website is working. Does anybody know how to fix this BitDefender about a blank issue?
Read more
My laptop can not boot and simply says error code 80004001 that I tried a complete reset, but it does not seem more vital than I developed it.
Read more
We have time synchronization issues in a very Windows 2003 R2 domain environment. I bully the Microsoft article "kb 816042 the ability to create an authoritative time server for the associated degrees in Windows Server" to check if our domain for W32Time is organized properly.
Read more
I recently in Windows 8 I buy this message once the language of the error volpanlu.exe, 0x693fefa7 of the at0x03ef9b34 has not been able to navigate.
Read more
I have a Windows 7 home network with an HP. Deskject 5940 running on a Windows 7x32 computer. The printer is shared and resides on a Windows 7x64 laptop. However, after trying to add a shared network printer on the laptop, I buy error 0x000006b5. I guess I want the x64 driver and look at the computer. I see that the x64 driver is not installed. But do I get the x64 drivers on the x32 computer for the laptop to use the printer?
Read more
Hello. The problem appeared suddenly after the PC was victimized for four years. A few days later, the error was not started and displayed: Error 0xc000035a \ Windows \ system32 \ winload.exe: You tried to load a 64-bit application, but the processor is not compatible with 64-bit mode. I have tried in some ways to use a similar hard drive, but no matter what I have already installed during the main reboot, the above error seems to have occurred. Please, someone, tell me how to fix 0xc000035a error?
Read more
A red X in the top line indicates D; \ hpzsetup and in the box "Fatal error during installation". Now all the opposite sections of the code are just loaded; HP offers electronic image and print creations, not the HP Solution Center. HP Chat could not solve the problem. They told me to transfer all the Operate drivers. For HP 6/7 printers, it's often the main printer I've had problems with. The installations have been tested from completely different readers. How can I solve this hpzsetup exe error?
Read more
I always receive the following message: Shut down the system - The system is down. All sentenced changes are lost. The system method 'C: Windows \ System 32 \ services.exe closed unexpectedly with permanent code 1073741482. The system can currently be shut down and restarted. I tried the clean boot and one thing was not working anymore. I put it back at the classic start. I tried running a scan, but it did not add a clean boot state. In addition, no automatic update has been enabled. Can anyone help to perform nt authority system shutdown fix? Read more
