Archive
I am trying to register an FM20.DLL file on an experienced Windows 7 64-bit operating system containing only an industrial software package. I took them in my SysWOW64 folder and executed the regsvr32 command. but I get the following error: The FM20.DLL module has been loaded, but the decision of DllRegisterServer failed with error code 0x80040151. Can someone tell me how to register fm20 dll in Windows 7?
Read moreSFC reports corruption that can not be resolved. DISM reports that the parts store is corrupt. I tried a clean boot without changing the error as soon as I try to install. I tried to modify the update catalog but shows error 0x80242006 when I try to install it. Please help!
When I start the PC, an error message is displayed: The program can not be started because of stservice exe system error on your PC. How can I solve this problem?
Read moreI loaded the Idiom Worldserver desktop workbench, but I continue to receive error messages. The prompt says cordbg exe JIT debugger error. An attempt to start a JIT computer program with the following command resulted in a voucher code of 0x2 (2). Please check the PC settings. Cordbg.exe! a 0x238 I uninstalled and reinstalled Microsoft .NET Framework one.1 Service Pack 1 as requested for the package. It is indicated to run with various infrastructure service packs, but it still displays a constant error message.
I run my Xbox One console and visit "Parties" and right away, it says "an error has occurred with your party" error 0x801900CC. Because of that, I even have a lot of problems with my friends or I start a banquet and it gets very annoying. What can I do to fix it? Please facilitate.
Read moreI get this error 80071a90 vista when I try to insert a scene update at resuscitation says "Configure updates and not configure updates successfully"I was really looking for this error code and did not notice it. Communities can you activate it?
I logged in to my computer and an error message saying: "ONENOTEM.EXE - System error: the appliance can not start because AppVIsvSubsystems32.dll is missing on your computer Try reinstalling the program. "Then I tried to start Word and get a corresponding error. I tried PowerPoint to start the same message. So I tried to see if the repair would work, but it did not work. How can I solve the problem?
Read moreI recently removed several viruses and spyware from a friend's laptop using a combination of Norton, housecall.trendmicro.com, Spybot and Adaware. Everything seems to work, except that ... here is the trap. I am currently receiving the message "MSSvc.exe has encountered an error and wishes to close". I bring back after connecting to the PC (after a boot) or, if this does not happen, I will buy it after running it. No additional viruses or spyware were found and I have analyzed the registry MSSvc.exe, but without success. Does anyone have ideas? Thank you
Read moreI tried to run the Outlook 2003 monitoring and repair tool, but it still depends on the following error: "Setup error: file not found. A required ZF612707.CAB installation file was not found. I have the first Workplace 2003 Optical CD in the drive, but apparently, there is no ZF612707.CAB on it. I tried to find it manually on the optical disk. When I Google ZF612707.CAB, I find that many people have an equivalent problem, but no solution. What is the euphemism ZF612707.CAB?
Read moreI tried to activate my windows in my new laptop but when I tried to do so an error occurred that says error code 0x800723b. I tried hard to resolve it can somebody give a solution that will surely work?
