Archive
I saw a file in my windows task manager with name tcl83 dll and it shows the processes as running but when I run the program associated with it. An error message prompts saying tcl83 dll is missing. Can someone bring up a solution to this error?
Read moreToday, after turning on my laptop, it crashed while Windows was loading. I saw this error: BUGCODE NDIS DRIVER BSOD. I am using a Windows 8 laptop. Please help me repair it. thank you.
Read moreI cannot access Windows updates, the web page is not even loaded and error code 80072eff windows update XP is displayed. According to my AVG antivirus, I have an outbreak called Win32 Patched. That's what happens and if you have a plan on how to sort an assortment, AVG can not handle the problem, thanks.
As with everything you do, try to correct a disadvantage that would lead you to another disadvantage. It starts with auto-typing not saving the username and word to do anything and the hours of your time, and it still has not worked. Which leads me to regsvr32 / u rsabase.dll and therefore to the error message I get; The rsabase dll failed to load. Make sure that the binary file is stored under the desired path or correct it for problems with the binary or dependent DLL file. the desired module was not found."
Read moreWhile opening the command prompt an error occurred that says the extended attributes are inconsistent Windows 7. I am unaware of this error completely blank about what to do next. Any sort of help or support is requested.
Read moreI was trying to use LogMeIn but it prompted LogMeIn error 1920. However, I tried to solve it a lot but the issue doesn’t come to an end. I don’t know why. Please help me solve this.
I can play CDA files on my desktop. However, I cannot play similar CDA files on my laptop. I get an error code C00D1199. I tried to download the Microsoft Codec installation package on my laptop but could not, present a disadvantage related to the incompatibility with Media Player11. I would like I appreciate each solution for the current problem.
Read moreMy system gave me an error of api32 dll missing so I had decided to perform api32 dll download. But will downloading this file solve the problem. How can I make sure that I am actually downloading the correct version or not?
Read moreHow to fix the STOP 0x000006b error. According to the Microsoft Knowledge Base, this is done using the bootcache.cat file. What is this bootcache.cat file?
Hi, my system has just gone through a new update in some files and now it shows error code 0x80072f05. I know this code happens due to the corrupt file system but I have just updated everything in my system anyone can tell why is it happening and how can I overcome this?
Read more
