Archive
While using my bing an error prompted to me suddenly that says “bsvcprocessor has stopped working”. Just a while ago from this prompt, I was able to use bing very nicely but after this, I am not able to use it even once. Can you please tell me how to solve this problem?
I had just updated my windows 10 with all the recent updates that came in my system. However, now my system doesn’t restart and given the error code 0x8024a112. Can somebody help me in solving this?
Read moreADS Instant Telecasting PCI This device is built into the laptop but cannot be started. It says ads instant HDTV PCI cannot start code 10. What is the meaning of this error and how does it start to work?
iTunes64.msi is missing and I cannot update or uninstall iTunes unless this file is present. Is there a reason to pass it on or notice it? How do I find itune64 msi file?
Read moreI installed Skyrim and then when I tried to run Steam I get the error message steam_api dll is missing skyrim. I do not have a lot of experience with adding mods to my games and I am afraid that I have corrupted my Steam Client? Is this the case?
I have used Windows live mail a lot. It works fine, but sometimes it simply crashes in between and throws the socket error 11004 windows live mail. How am I supposed to remove this error and make it normally work like it used to?
I do not know what to do anymore. I purchased an APTV and I was unable to view any channels on sling and it throws the following error sling error 10 402. At the same time, I can use Sling on other devices without any problems. Is there any way to solve this?
I checked my steam folder, and I was really confused to find that I had no steam.exe file but a steam exe old file. Are these files the same or not? What is this file? How do I get the steam.exe file or is it not necessary?
Read moreAfter launching the steam app, when I try to open the Steam store, I get the steam error code 130. I cannot access the Steam Store. Is there something wrong with my Steam client? Do I need to reinstall the Steam client to remove this error?
My steam client launches just like normal. If I do anything other than accessing the store, no problems occur. If I access the store on the Steam app, the following error occurs steam error 503 service unavailable xid. How am I supposed to get past this error?
