Archive
I am using my windows-7 pc for so long. When I am trying to update my app, which I am running for a long time, it showed windows-7 update error 80246007. There is no much description about the error. It just says that the update fails. What to do now?
I am using windows for a high time. Now when I am attempting to update it is showing Windows 7 error 80246008. The description says that there is a problem with the background intelligent transfer service. When I started to find it, I haven't figured them. Is this the reason for the error?
I am using my system for two years from now. Nowadays, when I am trying to back up my computer, it is showing Windows-7 backup error code 0x81000019. The description says a shadow copy creation is not possible, check VSS and SPP application. It's about space issues, but I have enough space in my system. What can I do now?
I am using windows 10 in my system for a very long time. Couple of days back when I tried for the update of my windows 10 I got the windows-10 upgrade error 0xc1900201. I have tried several times to resolve the issue and tried by reinstalling windows 10. How to solve this?
In my sister's laptop when we tried to start, it asked for windows update even it is windows 10. When I updated, it failed with the windows-10 upgrade assistant error 0x8007000d. It also failed when I tried to update with windows update. I have run windows troubleshoot but of no use. What can I do now?
Whenever I attempt to modernize my windows 10, it shows me different types of errors. It shows me the update failed to install with windows-10 update error 0x8024002e when I am trying to download an update on windows server update service. What does this error mean? How can I solve this error?
When I am trying to update my windows 10, it is showing the error code 0x80244007 with some description. I tried to troubleshoot the windows, and it fixed some errors in download, but this error is still appearing when I am trying to download the updates.
I am trying to update my pc for three days, but it is showing the error. When I click update on the control panel, it just stops. While I attempted to apply the media creation tool, it showed me the error 0x80080005 0x90016. It is just saying that it is loading. What can I do to remove this error?
I have updated my system from windows 8.1 to windows 10. Now, when I am trying to sync my email with the default mail app, it is showing me the windows-10 mail error code 0x80072af9. I turned all the permission on and tried it. The third-party mail is working without any problem. How to use the default mail app without any problem?
I have 1703 creator on my system. Recently when I am trying to install windows 10 1709 with some security things, it is showing windows-10 error code 0xc1900201. My operator said that the system reserved partition space is small and needs to extend. When I am trying to change the settings, it is not allowing me to do so. What can I do know?
