Archive
Recently I formatted my system and upgraded it to windows 10. From then every time it boots, it says as installing updates and then says updates failed and starts undoing. It then reboots and continues and opens the windows. I know nothing much about this, but now I am getting windows-10 error 0x800703ed. What is the reason?
I upgraded my c to windows in the morning. The pc has worked well for some time, and after installing some programs and restarting the pc, it showed some error like
driver_irql_not_less_or_equal MFEWFPK. I have upgraded my friends pc initially but never got this error. What can be the reason for this error?
I usually backup my system in night time in sleep mode. From some days it is showing the error code 0x8078014b unable to create the directory in backup storage. When I try to back up again, it is not showing any problem even I am using the laptop. What can be the reason for this problem?
When I try to open my system from sleep, I got an error which is solved when I reboot my system. From the next day, whenever I am trying to open my computer, it is showing windows-10 error 0x8009002d. It is asking to reboot the system every time. What can solve this problem?
I tried to install NetFlix in my system, but it showed an error. With my friend's suggestion, I thought to update my Wii System, but when I tried to install the update, it got a Wii update error code 32007 and stopped the update. What can I do now to install the update?
Whenever I am attempting to link to the internet using my new Wii U, I am getting a Wii U error code 103-1601. The description goes as it can't connect to the internet as more devices are using the same IP address. No one in the internet company can solve this problem. How can this be solved?
I used a wireless connection for Nintendo for video streaming and gaming, but the speed is low using that media center. Now I brought a USB to LAN adapter for connection. When I am trying to connect, it is showing Wii error code 51421. What can be the reason for this?
I have a router which I am using for a long time, and it is still working. When I am trying to connect my internet to the Wii console through the Wii LAN adapter through the instructions in the Wii menu, I am getting Wii error code 51420. How can I solve this?
When I try to connect using my net I got error 86420. Then I followed the steps in the Nintendo video to manually set the wifi. Now, I am getting Wii error code 50300 when trying to connect. Is there any mistake while connecting the net? What does this mean?
I used to play Mario a lot. Due to space issues, I deleted it long back. Now when I am trying to install it again, it is showing the Wii error code 201022, and then the download gets failed. I downloaded it several times, but it is just repeating the same. What can I do now?
