Archive
Hi, I am a regular Microsoft office excel user, but what can I do if I wish to lock the document before I send it to someone? I don't want the sender to edit my file.
Read moreHi. I needed help to calculate my internet bandwidth for my work at the office. It is not my area of work, but as an employee, I got to do what I was told to do. So can anyone please help me to check the bandwidth and suggest a simple internet bandwidth calculator?
Read moreHi, I am a nontechnical person, and I need help in removing an internal server error 500 IIS, which I am facing while loading my PHP file. Please help me with a simple solution that I can implement easily.
Hello. I am a nontechnical person, and I need help with some technical issues (Internal ole automation error). I am getting an error (-2146232376). I need to remove it. Please help me with a solution. It’s urgent.
Please help ASAP.
I have come across ‘Virtual Network Editor’ many times while I use VMware Workstation. What is a VMware Virtual Network Editor? What is it for and how to use it?
I need to update my Virtual Machine. I have got to know that some sort VMware Update
Manager is needed to update it. Is it true? If yes then how to install it?
I use VMware and take many snapshots. Its default file location is very difficult to reach out to whenever I need it. So, I need to change the VMware Snapshot file location from its default value. Can
someone tell how?
I want to use VMware on my server. How to install VMware on Windows Server 2012? What
are the system requirements for installing the former?
I’m a virtual machine user. I need to know about VMware ISCSI Software Adaptor. What is
These VMware ISCSI Software Adaptor, what is there usage, and how to configure them?
Hi there, I am a user of virtual machines that are independent of any operating system. High availability is among its requirement. I need to know if VMware ESXi High Availability is the right option or not?
