Archive
I upgraded to Windows 10 from a previous version, but Windows Defender is not working. I am unable to turn it on as I am facing the 80070426 error. I have no clue how to get rid of the error. Please help.
Read moreI get an error code – 80070425 on my Windows 10 PC. The error message is that the credential manager cannot accept the control message at this time. How to get rid of it?
Read moreWhen I try to update my Windows 10 version, I encounter an 80070422. The troubleshooter did not solve the problem, and all the Windows update services are running. What to do?
Read moreI cannot sign in to Xbox Live. I am getting an 80048821 error code. I have an active membership, and the password is also correct as I verified it using the Microsoft site. Restarting did not help. How to fix the problem.
Read moreIn the Windows Update center, I find this error - “Feature update to Windows 10, version 1803 – Error 0x80242006.” Is there any way to get rid of this error?
Read moreI need help in solving an error on my PS3. Kindly tell me the methods to fix the 8002f281 error (PS3). Thank you in advance.
Read moreI have a Macbook. When I try to delete files from the Trash or attempt to empty trash, I encounter an 8003 error. How to fix it?
Read moreI am unable to use my PS3. I encounter the 8002a537 error code. I am unable to find any solution. Is there any solution available for the 8002a537 error code on PS3?
Read moreWhen I try to update Windows 10 using the Windows update center, I encounter the 800072ee2 error. I ran the troubleshooter, then restarted the services, renamed the software distribution folder, and turned off the firewall, but could not solve the error. Is there any other way to fix the error?
Read moreI encounter an 80004005 error when I open VirtualBox on my Windows 10 PC. The Virtualization setting is on, and I have all the necessary components. I am using VirtualBox for the first time, and I have no prior experience. Is there any way to solve the issue?
Read more
