Archive
I am trying to connect my iPhone with iTunes on my Windows 10 PC. I am getting a 0xe80000a error, and I am unable to connect. I checked that the USB is working well and performed updates of my Windows, iTunes, and my phone. Please help.
Read more
I am trying to sync iPhone with iTunes. I am using a Windows 10 PC with iTunes to do the same. I am getting a 0xe8000065 error. I am not a very tech-savvy person, but can I solve this error on my own?
Read more
I have an HP printer that is connected with my Windows 10 HP laptop. When I try to print color photos, I encounter a 0xe06d7363 printer error. I will be very grateful if anyone can suggest a fix. Updating the drivers did not help.
Read more
My laptop is behaving weirdly. It runs on Windows 10 and suddenly throws the 0xe0434352 error when I open certain applications. How to fix the error?
Read more
I am unable to install the AVG antivirus as I am encountering a 0xe001003d error. I removed the previous antivirus, but the problem persists. How to install AVG?
Read more
Do you know a way towards fixing the 0x9f driver_power_state_failure_exception windows 7 error?
Read more
Hey, I was stuck with this 0x9c machine_check_exception error inside my PC. Can anyone help to rectify this 0x9c machine_check_exception error?
Read more
Hello, I was stuck on this 0x8e5e0408 error message for a while. Can anyone tell me what is this 0x8e5e0408 error and please help me fix it?
Read more
Hi, I was getting this 0x8e5e03fb error a lot while using my PC. Can anyone fix this 0x8e5e03fb error?
Read more
Hello, I was stopped by this 0x8e5e03fa error while I was using my PC. Can anyone assist me in finding an easy solution to the 0x8e5e03fa error?
Read more
