Archive
Hi, I am getting 0x8002801c error in Windows 10 that says DllRegisterServer failed. I cannot understand the solution to this problem. Please help me out here!
I use Microsoft Windows Server, and I recently ran into a problem. The server reboots itself, and when I checked the log, I got the code 0x80020002. How can I solve this issue?
Read moreTo solve 0x80010135 error while extracting a file in Windows 10, follow these methods.
Method 1- Rename the file.
a. Right-click on the file.
b. Click on Rename.
c. Rename your file as a.zip (use a single alphabet, not necessarily a).
d. Extract your file.
Method 2- Download 7-zip.
a. Go here
b. Download the software (.exe) for your Windows (64-bit or 32-bit).
c. Run the .exe file.
d. Extract your file using 7-Zip.
I am unable to update Windows 10. I am encountering a 0x80010108 error. I ran Windows Update troubleshooter, but it was of no help. How can I fix this error?
Read moreI am using Windows 8.1, and Windows Defender throws an error when I use it in my guest account. The error code is 0x80010005. How can I solve this problem?
Read moreI had an issue with my Windows 10 laptop, and I was trying to restore it to the previous time, but I face another issue there that I am unable to solve. Please, tell me how to solve the 0x8000ffff catastrophic failure Windows 10 problem.
Hi, I am unable to boot into my Windows 10 as it is stuck at the start-up screen with 0x490 error. How can I fix the 0x490 Windows 10 error? I followed some instructions to boot my PC in safe mode, but it did not help.
Read moreI am unable to open Microsoft Office on my Windows 10 laptop suddenly. I get a 0x426-0x0 error stating something went wrong. How to troubleshoot this?
Read moreI am trying to run a task using the task scheduler, but I am unable to do so as I am encountering a 0x41303 error. I am unable to understand the problem. Please help me out.
Read moreIn my task scheduler, I can see a task that shows 0x41301 in brackets. This task is running for a long time. How to put an end to this task?
Read more
