24 x 24 Pixel and 16 x 16 Pixel Icons
How long has the 24 x 24 pixel and 16 x 16 pix standard for Windows icons been in effect? Have those always been the standard? Or, was that standard implemented long after Windows became popular?
Hi Jean,
This 24 x 24 pixel and 16 x 16 pixel standard for Windows will help you to convert icon from your picture/ photo/ image files. It is also quickly resize your images in a .JPG, .GIF, .PNG, .ICO, .BMP and .TIFF formats w/out having to install an any software on your PC.Â
Dear JeanGivan,
When you are speaking about the standard icons or recommended size by windows first:
The recommendations of the icon sizes from Microsoft says that icons should include
·  48 x 48 pixels
·  32 x 32 pixels
·  16 x 16 pixels
·  But if you are using icons for making tool bar it is recommended using 16 x 16 pixels or use 24 x 24 icons.
