arturo owen
10 points
Posted on - 02/15/2012
Hello!
Possibly I am in the accurate forum. I was suggested to use the auslogics disk defragmenter. But when I have used it, the system health menu shows me the following error:
252 junk files and 144 registry errors.
Need your help. Thanks.
Pre simple solution for this error, Do the followings:
1. Go to start.
2. Run.
3. Type cmd.
4. Hold down shift and ctrl and press Enter.
5. Run it up to the three times if there error it will find that.
6. Do according.
7. Also have to download and use cleaner. 8. Have to unstick the registry section, unless you are proficient in that area.
I have a good solution to fix your problem when you have “252 junk files and 144 registry errors”. You can fix the problem on your own and I have some solutions how you can do it. Some solutions are given below.
If you are a Windows XP user, first, go to Start > Run and type cmd and press Enter.
In Windows Vista, go to Start > Run and type cmd. But if you are a new user, then you can’t get the Run menu. So write ‘run’ in the search box or find run in the menu. Then type cmd.
Now you can see a window which shows c:chkdsk/f
You have to reboot your PC. While it is booting, it will check the drive automatically.
At the time fixing errors, check the Disk dialogue box for the file system integrity status.
It performs the checking of the disk surface and fixing physical errors and bad sectors.
You can also defrag other disk drive such as :D, :G,:H, or :F.
If you want to do it with the software you have, download the correct version with the appropriate serial key.
If you still see the error message, then you have to uncheck the registry in the software.
