270. How To Print Large Images On Word?
Hi! I need to get the hard copy of a big sized picture on the regular pages. Can anyone help me and tell how to print large images on multiple pages?
For the professionals, a lot of options are available to carry out this particular task. But, as for the rest of us, it is not what we call as ‘easy’. So, I am here providing you with the process that uses the most basic inbuilt app available on our Windows systems. To begin with:
• Open the image (the one you would like to print) in Paint.
• Select Print > Page Setup or File > Page Setup as per your Operating Systems.
• Change the settings for the number of pages under ‘Fit to’ option in the Scaling tab.
• Click OK.
• Select All Pages, and then print the picture from Paint.
