Is 350 kbps a lot for mp3?
I have 350 kbps mp3 player and I'm wonder if that means that my mp3 player is of high quality? If not, I'd require a list of mp3 player that have a higher bitrate than that as well as a lot of space.
I will clear your doubts regarding mp3. The mp3 format supports upto 320 kbps. It could be variable or constant bitrate. You can have higher bitrates in Flac, Aiff, Wav formats. They take a lot of spaces. If you need a good mp3 player with lots of space, then buy Apple iPod Touch 32 GB. You can have thousands of mp3 files with it.
Yes, 320 kbps is the best audio bit rate in mp3 format. Normally mp3 found only in 128 kbps if you have 320 kbps than you have good sound quality.
List of mp3 players
Apple iPod Touch 8GB
Apple iPod Classic 160GB
Apple iPod Touch 5th Gen 32GB
Hello Kitty iPod Nano 16GB
Apple iPod Touch 4th Gen 16GB
And many other visit this website for better mp3 players
