Hello Friends,
I am having a 40 GB drive which is an NTFS partition for which I would like to restore the lost data. Please suggest me the best 40GB RAW data recovery freeware that will help me to restore the data  through fasted scan speed and best recovery ability.
Thanks in Advance,
George Saunders
There are many tools for data recovery from a disk so , long as the disk is not spoilt.
Try the following
EaseUS Data Recovery Wizard
The lost data still exists on the hard disk, but can't be located by the operating system. Recovering an overwritten data or data that is in damaged cluster is impossible. If they meet the conditions for recovery, the free data recovery software can scan cluster by cluster trying to analysis the data and to determine if they can be recovered.
PC Inspect file recovery is another great tool that you can use.
Best of luck
Hello George!
How are you?
Why don't you try Power Data Recovery Software to recover your lost data on 40GB hard drive, with more reliable method.
The ever best software I found, with multifunctionality.
You may recover your data with 3 different ways.
1) If your files are damaged or corrupted you can use Undeleted Recovery Method.
2) If you want to recover a file from a specific folder existed, you can use Advanced Recovery Method.
3) You can also recover your completely deleted/formatted data with Deep Scan Recovery Method.
4) Software is easy to use and low cost to purchase.
Following is the link to software site:
https://www.powerdatarecovery.com/
Regards
Richardd Wyatt
