Alex sandara 50 points N/APosted on - 09/23/2014
My mobile data company is pushing me to buy a new phone with a 4G plan. This would be significantly more expensive, and I won’t have unlimited data of internet use. However, they guarantee that I would reach an ADSL speed on my phone, which would be quite handy. I still remain unsure, however.
Is it worth it? Should I wait for the prices to go down a bit? Is the increased speed really noticeable?
There is no doubt about 4G is much way better then 3G as it is 10X faster. But that is just a technical thing. Then question that any user should upgrade to 4G is all about usability for that particular user. If you are just a very average user, who hardly use phone for receiving calls or SmS, then I will not suggest you to spend such a huge extra cost. But if you are real tech geek, whose life rotates around the their smartphones using different apps and internet throughout the day and night, then this is really worth for you. Advantages ogf 4G over 3G are:
Faster downloading than 3G:
Now no more annoying long waiting times for uploads and downloads, varies form an image or video uploads or web page refreshing, even zero buffer time for video streaming. Even online music playback will also improve.
Amazing video calling:
Video chat will be free from the requirement of broad band connection. 4 G will provide you the facility of anytime and anywhere video calling .
Gaming:
Now you can enjoy full-fledged gaming experience on your handset only, as you enjoy at your home setups. Lot more then “Angry-Bird” and “Subway-Surfer” like games.
Hot spotting:
This is one of the best features about 4G network. You will be able to share your network by creating a hot spot on your mobile. In this way you will be able to share your smartphone’s data usage over your PC or Tab.
That’s true, 4G is significantly fast than 3G and at the moment the development on 5G is on its way. Here’s an example of a device with 4G support: the Sony Xperia Z4 LTE tablet. There are many variants in the Sony Xperia series of tablets and one is the Sony Xperia Z4 LTE tablet.
Sony Xperia Z4 LTE
The Sony Xperia Z4 LTE is a 4G tablet operating on 2G, 3G, and 4G network bands using GSM, HSPA, and LTE technologies. It was announced to the public on March 2015 and released on June 2015 measuring 254 x 167 x 6.1 millimeters and weighing 393 grams. It uses nano-SIM card and is IP68 certified (dust proof and water proof up to 1.5 meters for thirty (30) minutes).
It has IPS LCD capacitive touchscreen display with 16M colors at 2560 x 1600 pixels screen resolution. It is protected with scratch-resistant glass with oleophobic coating, Triluminos display, and X-Reality Engine.
It ships with either Android 5.0 Lollipop or Android 6.0 Marshmallow upgradable to Android 7.0 Nougat powered by 20 nm Qualcomm MSM8994 Snapdragon 810 chipset, Octa-Core processor (4 x 1.5 GHz Cortex-A53 & 4 x 2.0 GHz Cortex-A57), and Adreno 430 GPU. It supports microSD expandable up to 256 GB. It runs on 3 GB RAM with 32 GB internal storage.
The primary camera supports 8.1 megapixels with AF featuring HDR and can record video in 1080p at 30 fps with HDR support. The secondary camera supports 5.1 megapixels.
It has 3.5-millimeter jack featuring active noise cancellation with dedicated mic; Wi-Fi 802.11 a/b/g/n/ac with dual-band, DLNA, Wi-Fi Direct, and hotspot support; Bluetooth 4.1 with A2DP, LE, and aptX support; GPS with A-GPS, GLONASS, and BDS support; NFC; FM radio with RDS support; and microUSB 2.0 with MHL 3.0 TV-out support. It has built-in accelerometer, gyro, compass, and ANT+ sensors.
It runs on non-removable 18W Li-Po 6000 mAh fast charging battery. It is available in black and white colors.
1....
