Hello everyone! From the past one week I have noticed that sometimes when I am trying to open a webpage, the webpage does not open properly and a message in big black bold text is displayed which says the following "504 Gateway Timeout". Is it related to my Internet, do I have a problem of the connection or the website issue? I have to refresh the site many times before the actual web page is opened. What is the reason for this? Thanks!
504 gateway time out on websites
Hello!
504 Gateway error is a feedback error that will be posted if one of the machine communicating wasn’t able to respond in proper time. Meaning to say it’s either the server you are trying to connect to is not responding or down or your connection were interrupted. To fix this simply click “F5” or refresh options in your keyboard as many times. If that doesn’t work try to clear your cache, cookies or any browsing history. Close your browser and re-launch again. Try to turn off modem and turn back on after 30 seconds. Disable and enable your LAN (Local Area Network) cards or network cards. Try to check also if you can still connect to other websites. If this will not work with the site you are trying to connect the problem is with the website itself.
