I recently got a 5.1 surround sound home entertainment set and tried to connect it to my computer.Â
When I plugged it in via a Cable Jack it only brings out the sound of 2 speakers. The others are just making a noise like bad feedback.
I also installed RealTek Audio manager as my sound driver. But it still doesn't work.
What can I do?
5.1 speakers with only 2 speakers working
Hello Hillary,
When listening to music, only two speakers are working because it's only two channels, the left one and the right one, that's normal. And about Logitech speakers, you get surround from stereo files you have to push the matrix button. If that doesn't work or you don't dispose of such button, right click on your sound icon in the task bar, next click playback devices.
Select speakers, then click configure. Go to the enhancement table and check the speaker fill in the blanks of checkbox and click apply. That will divide music to all of the devices.
Banaay22
Hi good day,
I will give the direction how to enable 5.1 speaker, go to star menu >>> click control panel then click classic view >>> find sound icon click on it >>> then in the upper corner their is speaker icon right click >>> click on Configure Speaker >>> click 5.1 speaker >>> click next >>> next >> next and Finish >>> then OK.
Thank you. Hope it work.
To configure your computer for the new surround system added on your computer, click on Start> Control Panel> Hardware and Sound. Click on the Manage Audio Devices on the Sound option.
Select the Speakers and then click the Configure button. It will launch the Speaker Setup and then select the 5.1 Surround from the list. Click to test each speakers and then Next to select the full-range speakers. Just click on Next to select speakers and test it until the configuration is done. Your new settings will be applied.
